June 22, 2020 at 4:48 pm
ssss
SubscriberI'm trying to validate some wind tunnel simulations. My geometry consists in 5 spires at the entrance of the wind tunnel, and various roughness elements (square blocks) at the surface of the wind tunnel. I attach the print of my geometry.
 I have already tested different methods and sizes of the elements, but I could only achieve this: skewness Min 1.31E-10, Max 0.99842, Average 0.21809. The orthogonal quality is Min 1.58E-03, Max 0.99999 and Average 0.78044.Â
How can I reduce my skewness?
Thanks -
June 23, 2020 at 4:13 am
Keyur Kanade
Ansys Employeeif you are going to use fluent, please check orthogonal quality. if min ortho quality is greater than 0.1 then your mesh is good.Â
please find the locations of bad elements. please check following video.Â
then apply different sizing at those locations. in some cases you may need to modify geometry at those locations.Â
https://www.youtube.com/watch?v=AzvPxjNyr3w
Keyur
If this helps, please mark this post as 'Is Solution' to help others.
June 23, 2020 at 4:14 pm
ssss
SubscriberThank you Keyur for your answer. Yes, I will use Fluent.
The orthogonal quality of this mesh is Min 1.58E-03, Max 0.99999 and Average 0.78044. What do you think about this?
I identified that the spires are the ones that present the bad elements, as you can see below.
How can I apply different sizes in these specific locations?
If that doesn’t solve the issue, I can try to modify the geometry in these locations, as you suggested, but I am not sure how to do that as well…
Thanks, Sorte
June 24, 2020 at 2:32 am
Keyur Kanade
Ansys Employeebest way is to modify geometry.Â
if you want to change sizing, please see below.Â
https://www.youtube.com/watch?v=w4q6q8nKF3U
Keyur
June 24, 2020 at 10:16 am
ssss
SubscriberThank you for your reply. How can I modify the geometry?
I am very new to this software, and I am trying to learn it in any possible way. Thank you in advance.
June 24, 2020 at 10:35 am
Forum ModeratorGo back to the Geometry tool. It will probably help if you do the tutorials that come with the Help function.Â
- The topic ‘How can I reduce the mesh skewness?’ is closed to new replies.
4052
1482
