October 28, 2020 at 6:00 pm
Hoosein86
SubscriberOctober 28, 2020 at 7:21 pmDrAmine
Ansys EmployeeDo you want to plot the velocity before running,? Not possible.nnDuring the run just create area average of velocity at inlet and activate report plot.nJanuary 19, 2021 at 8:35 amHoosein86
Subscribercould you please write in detail about how should I do this?nThanksnJanuary 19, 2021 at 10:28 amDrAmine
Ansys EmployeeYou Create Report Defintion, You select the variable you want to monitor, select where to be monitored, enable report plots and report files. Now if you are running the case unsteady Fluent will show a plot of that vs time.nJanuary 19, 2021 at 11:22 amHoosein86
SubscribernJanuary 19, 2021 at 1:39 pmHoosein86
Subscriberunfortunately, I didn't find it.nJanuary 20, 2021 at 11:52 amRob
Forum ModeratorIn the xy plot panel you'll find a button axes, start there. nViewing 9 reply threads- The topic ‘How can I make Velocity-time Plot in ANSYS Fluent Postprocessing?’ is closed to new replies.
3757
1333
1168
1090
1014
