November 19, 2020 at 10:41 amsaadiaSubscriberNovember 19, 2020 at 2:43 pmAniketForum ModeratorYou will need to manually split the faces (assuming it is a 2D model, if it is 3D, you will need to manually split the solids) and use face sizing to get mapped mesh.n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning ForumnNovember 23, 2020 at 4:34 amKeyur KanadeAnsys EmployeeSplitting the faces will give you a good structured mesh. nIf you can please use inflation and tri mesh. nRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnnViewing 2 reply threads
- The topic ‘How can I make a uniform meshing in the bypass area of this dual throat nozzle?’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- ICEM CFD – Hexa mesh of a tapered wing with sharp trailing edge
- No mesh information was found in the input mesh file error
- CONVERTING STL FILE IN TO SOLID
- Varying ply angle in ACP
- Element type definition – Ansys Workbench
- ANSYS ACP Modelling Issue
- the matrix T in the cyclic symmetric formula!!
- Assiging one parameter as thinkness of few shell objects
- The meshing algorithm cannot find matching topology
- Connecting External Mesh and Beam Model in Ansys Workbench
Top Contributors-
1381
599
591
550
366
