November 19, 2020 at 9:06 am
Shaimaa
SubscriberDear all,nI simulate an example to separated between two layers ,How can I know is there is a separation done after solving the simulation ,Can I know from the displcemant or there is anther simple way???nThanks in advancen -
November 23, 2020 at 3:23 pm
Aniket
Forum Moderatorcan you please explain the query in some more details? which software are you using? If using Mechanical with frictional contacts, you should be able to use contact tool with the gap and check status.n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumn
- The topic ‘How can I know if There is a separation done between two layers???’ is closed to new replies.
Ansys Innovation Space
1328
1163
1090
1014
