how can i get the values of heat gained by a certain surface and air in a box subjected to sun
    • AGAAMAZ
      hello everyone ;na closed box of aluminum is subjected to sun , after running transient solution nhow can i get the values of heat gained by a certain surface of the box and the air inside it ?n
      Use surface and volume reports. These need to be set up and monitored during the solution. The data file for Fluent contains instantaneous values and not the solution history. n
  • The topic ‘how can i get the values of heat gained by a certain surface and air in a box subjected to sun’ is closed to new replies.
