January 4, 2024 at 12:15 am
Xihang Shi
SubscriberI am using Lumerical Finite Difference IDE. I put a dipole at 1um above a dielectric, and then put a line monitor pass through the dipole.  I want to record the scattering field at the line monitor. How could I do that
The line monitor cannot distinguish the field from the dipole and the field scattered by the dielectric. I thought run another simulation with the dipole in a vacuum only as the background. However, the subtraction at the dipole point gives the wrong result.Â
Is there other way to distinguish the scattering field by the dipole at the dipole point?
January 5, 2024 at 10:40 am
Dimitris Polyzos
Ansys EmployeeHello Xihangshi,
I am not sure if the setup of your model is correct. The dipole source travels in parallel with the dielectric and the scattering needs a small particle or structure to happen. Correct me if I am wrong but I cannot see any small structure in your model. A little bit more information would be useful, or the reference of your model.
Howver, some useful information how to set your dipole source correclty can be found in the following links:
Dipole Source in Ansys Lumerical FDTD – Lesson 6, Part 1
Dipole Source in Ansys Lumerical FDTD – Lesson 6, Part 2
Dipole-source-Simulation-object
Some application examples where you can pump some ideas how to setup your simulation can be found below:
Bandstructure-of-photonic-crystal-with-loss
I hope I helped. Let me know if you need further help with your model.
Kind regards
Dimitris
January 5, 2024 at 4:17 pm
Xihang Shi
SubscriberThanks Dimitris.Â
The dielectric should scatter the dipole field. The point dipole at the red point in a vacuum, above the dielectric. Meanwhile, I put a line monitor in the vacuum too, parallel to the dielectric surface, and pass through the dipole point. Now the monitor can only record the total field, but I want the scattering field.Â
January 9, 2024 at 4:58 pm
Dimitris Polyzos
Ansys EmployeeHello,Â
I would recommend to check the far field of the reflection from the dielectric as I think that the near field for both monitors might be very similar to each other. First check the field that is above the dielectric and then the field of the monitor at the background. Please refer to the following links for farfield calculations and applciation examples
Polar plot of scattered field with particle on substrate
Far field directivity calculations of an antenna
Lumerical scripting language - Alphabetical list
I hope I helped. Please do not hesitate to come in contact for any query you might have.
Kind regards
Dimitris
- The topic ‘How can I get the scattering field by a dipole, at the dipole point’ is closed to new replies.
5729
