December 21, 2023 at 11:06 am
user deleted
SubscriberHello everyone. When modeling an antenna that bends, I want to get a constant value of the port coordinate, since the antenna itself bends, and the port does not change its location relative to the antenna. The bend of the antenna is set using a Wrap sheet around the cylinder. Is there a way to fix the port coordinate relative to the antenna when it bends?
December 22, 2023 at 5:31 pm
Praneeth
Bbp_moderatorHi,
Thank you for reaching out to the Ansys learning forum.
Please create the port using the edges of the top and bottom conductors. This will make the port move w.r.t to the antenna bend.
Best regards,
Praneeth.
- The topic ‘How can I get the coordinates of the surface for calculations in HFSS?’ is closed to new replies.
Ansys Innovation Space
1258
1107
1068
953
