How can I get same flow rate in injection summary as what I set in discrete point properties?
    • TSADEGHI
      I am simulating spray injection in a pipe. My model is multiphase (air as a continuous phase and water liquid as a discrete phase) using K-Omega viscous model. Regarding point properties for discrete phase, I set total flow rate as 1e-5 kg/s. When I got the results, total mass in injection summary is 8.45e-8 kg. Why this happened and what should I do?
      If you need more information on my model please do not hesitate.
      Thanks,
      Taha
      How long has the model run for?
    • TSADEGHI
      The model has run for 0.8s with time step size of 0.00015s. the whole injection process starts at 0.01s and ends at 1.51s.
      Have any particles reported as escaped, aborted, incomplete or trapped?
    • DrAmine
      You are looking in the wrong report. Please copy paste the screenshot of following command in the console /report des no yes no
    • TSADEGHI
      Thank you Rob and DrAmine, I found the mass of escaped particles and it was correct,
Viewing 5 reply threads
  • The topic ‘How can I get same flow rate in injection summary as what I set in discrete point properties?’ is closed to new replies.
