3D Design
3D Design
How can I fix the Error: Line-Body operation failed (Geometry: DesignModeler)
    • wh05
      Hi, I plotted the points and finished the horizontal lines by "Translate" ( which is Create -> Body Transformation->Translate)
      However, after drawing up the vertical lines, the vertical lines come out with red exclamation mark, which stated below:
      Context: Geometry Engine, while generating Feature Line7
      Will it affect my afterward analysis? How can I fix it?
      It means the line isn't valid. Right click on the entry in the tree and look to see if there are options to get more information: that'll help with the diagnosis.
    • sathya
      Hi Edit the input point in error line body again.May be you might have selected same points.
  • The topic ‘How can I fix the Error: Line-Body operation failed (Geometry: DesignModeler)’ is closed to new replies.
