Preprocessing
Preprocessing
How can I extract the FACES of a 3D geometry (from Fluent) into a .TXT file?
    • michele.ingemi123
      Hi. I am new to Ansys. I figured out how to extract NODES in the following way:
      File -> Export -> Solution Data -> File Type ASCII -> Select Surfaces -> Write -> NODES.txt
      How can I extract the FACES into a .txt file?
      A profile file will give you facet centre and solution values. What are you wanting to do with the data?
