TAGGED: parameter-sweep, structures, sweep, sweep-method
November 27, 2024 at 11:53 am
10172100207
Subscriber -
November 28, 2024 at 10:35 pm
Kirill
Forum ModeratorHello Subscriber,
This is not the typical workflow for a parameter sweep. Usually, you would obtain results from monitors or solvers during the sweep.
As a workaround, you can define a new variable as the result of the "model" object, assign it the desired value from the script, and then include it in the sweep results.Best regards,
Kirill-
December 2, 2024 at 7:46 am
10172100207
SubscriberThanks
December 2, 2024 at 7:44 am
10172100207
SubscriberÂ
1307
