March 31, 2022 at 5:41 pm
shaoyuwang
SubscriberI am simulating a heated metal block and after solving I want to create an isosurface at a specific temperature, but I can only find the command ANISOS, which can generates an animation of a series of isosurfaces, but cannot specify a specific temperature.
And I don't know how to export this isosurface as a geometric model, can anyone help me?
April 27, 2022 at 12:23 pmAniket Chavan
Forum ModeratorIf you read the result file in Mechanical, Plot the result in Mechanical using Isosurfaces, and right click on the result and export it as stl, you should be able to open it in SpaceClaim and get surface out of that.
-Aniket
May 4, 2022 at 3:21 pmshaoyuwang
SubscriberThank you Sir, it works!
But is there a way that I can realize it in APDL?
Viewing 2 reply threads- The topic ‘How can i export the isosurface to a geometry file in apdl?’ is closed to new replies.
