How can I export and then import a deformed structure?
    • Kimi K
      I conducted a buckling analysis on my geometry, and now I'm looking to export the deformed geometries for additional analysis. Unfortunately, I'm encountering challenges with the export process. I've seen suggestions on YouTube about exporting it as an STL file. Still, I'm struggling to convert the STL file into a format that can be easily imported back into DesignModeler for further work. Is there a method to export the geometry in a way that allows me to re-import it into DesignModeler seamlessly?
      Thank you
    • ErKo
      Duplicate closing this one – use the other post.
  • The topic ‘How can I export and then import a deformed structure?’ is closed to new replies.
