December 22, 2020 at 1:40 pm
AGAAMAZ
SubscriberHello Everybody
How can i apply on a glass slab a natural convection from top and forced convection from bottom ?
December 23, 2020 at 2:19 pmKarthik Remella
AdministratorHello,nYou will need to create an enclosure surrounding the glass surface at the top. All the boundary surfaces will be walls (4 on the sides and 1 on the top). You will need to activate gravity here. nOn the bottom part, you will need to have another enclosure. This time, there will be an inlet and outlet. You will apply the appropriate boundary conditions here (velocity inlet and pressure outlet). nPlease assign the material properties appropriately in these domains. nI hope this helps.nThank you.nKarthiknDecember 24, 2020 at 12:40 pmDecember 28, 2020 at 12:31 pmKarthik Remella
AdministratorHello,nThere will be no boundary condition on the glass down surface. Fluent will automatically apply the necessary condition here (Temp of the fluid = temp of fluid, and conduction flux in the glass = conduction flux in the air at the boundary).nThanks.nKarthiknViewing 3 reply threads- The topic ‘how can I do this in boundary condition please ?’ is closed to new replies.
5024
1714
1387
1248
