Electronics
Electronics
How can i define the motion setup on coil?
    • y2eliz
      I'm working on a Maxwell3D transient model.
      As you see in the figure, i want to observe the Torque - Displacement graph. How can i define the ±5 degree motion setup on coil? or how can i assign the band without "intersection error" on the coil?
      Thanks!
    • sarathmail63
      I think the moving material should assign inside a box. Refer this below tutorial you will get logic. nhttps://www.youtube.com/watch?v=LW9TcpkZaZY&list=PLNLmSKqKLg4fPrISWpjbrEYs7PcPwnMM4&index=7n
    • y2eliz
      Hi Chand,nnI've watched this video. Solution of this problem is draw the Band on the moving part. Thank you for your reply n
    • rtk
      Hello y2eliz,nIt seems like we somehow missed this post earlier. Apologies for that!nCould you please confirm whether you got a solution to this problem?. If not, we are happy to help you!nLet us know!nnBest Regards,n
  • The topic ‘How can i define the motion setup on coil?’ is closed to new replies.
