March 16, 2024 at 1:43 pm
March 16, 2024 at 10:30 pm
peteroznewman
SubscriberPromote the Remote Force to a Remote Point. Apply a Remote Displacement and scope it to the Remote Point you just created. If the axis of the spring is the Y axis, set X = 0 and Z = 0 and leave Y to be Free. That will constrain the Remote Point to move only along the Y axis.
March 17, 2024 at 8:38 pm
Noura Mansour
SubscriberThank you for your effort i understood but i have questions ..
why if i insert the displacement as a boundry condition i got a curve between force and displacement this curve not as same as when i insert the remot force as a boundry condition?
, when i insert remot force as boundry condiition the behaviour i used is deformable is it true ?
 ..and if i want to get chart be
tween force and displacement i insert reaction force scope it to the fixed support or to remote displacement ? i used it as a fixed support
March 18, 2024 at 3:35 pm
peteroznewman
SubscriberIf you use a Remote Displacement for the Y deformation instead of a force, you should look at the Force Reaction in the Y direction, which is the direction the spring is being compressed. I assume you don't want to look at the lateral forces the spring is exerting on the constraint trying to go sideways.
If you apply a Remote Force, the force is proportional to Time. Make the End Time equal to the final value of the Remote Force, then the Displacement vs Time plot can be read as Displacement vs Force.
March 18, 2024 at 6:00 pm
Noura Mansour
SubscriberSorry but i can't understand if i want to get a chart between force and displacement of spring what should I do?Â
i inserted a remote force as a boundary condition and in solution tree i selected directional deformation in y direction and reaction force at fixed support And then created the chart ..Â
Is it differ from if i make end time equal to final value of remote force?Â
March 18, 2024 at 6:26 pm
peteroznewman
SubscriberWhat you did works. The other method is slightly faster to get some data to plot.
March 18, 2024 at 11:15 pm
Noura Mansour
Subscriberhow can i apply the other method?
how can i change the end time
March 19, 2024 at 1:22 am
peteroznewman
SubscriberUnder Analysis Settings, where it says End Time and there is a 1.0Â type in the final force value.
March 19, 2024 at 1:26 am
Noura Mansour
Subscriberdefine also intial , minimum and maximum substeps?
March 19, 2024 at 10:43 am
peteroznewman
SubscriberJust like you did before.
- The topic ‘how can i constraint the compression of the spring to be in one direction ?’ is closed to new replies.
