November 25, 2021 at 5:49 pm
Rameez_ul_Haq
SubscriberI am conducting an analysis of a structure which is subjected to some external loads. However, there are some maximum limits defined for the center of gravity of that structure under these critical loading conditions, beyond which the structure will not be considered appropriate for use.
Now, what can I do in ANSYS to know the deformations and rotations for the center of gravity of my structure?
November 25, 2021 at 7:32 pmpeteroznewman
SubscriberInsert a Remote Point, Behavior=Deformable, scoped to the faces or bodies on the part of the structure you wish to monitor. A single point will be created at the center of gravity of the scoped nodes which will average the motion of all the nodes on that part of the structure. In the image below, I have one surface I am monitoring that is supported on another part that I don't want to include in the monitoring.
Use a Deformation Probe.
Use three Flexible Rotation probes.
November 25, 2021 at 9:30 pmRameez_ul_Haq
Subscriber,what if I want to check the rotation about a specific manually created co-ordinate system? I do see an option to choose the co-oridnate system for the deformation, but for the flexible rotations I cannot see it, in the pictures you shared.
November 25, 2021 at 9:45 pmpeteroznewman
SubscriberYou are free to edit the coordinates of the Remote Point and put that anywhere you want.
Viewing 3 reply threads- The topic ‘How can I calculate the deformation and rotation of the C.o.G of a structure in my analysis?’ is closed to new replies.
4618
1530
1386
1209
