December 4, 2023 at 1:07 pm
YEEUN KO
Subscriberhow can i calculate magnetizing inductance of transformer using ansys maxwell?
December 7, 2023 at 12:00 am
GLUO
Ansys EmployeeHello,
In eddy current solver, you can add matrix for windings in Parameters for inductance calculation. For transient solver you can turn on matrix calculation by rightclick the design name and go to design settings.
GL
December 7, 2023 at 5:10 am
December 7, 2023 at 7:12 pm
GLUO
Ansys EmployeeNormally magnetizing inductance is the mutual inductance in this mtrix. Please double check the transformer model online.
GL
December 8, 2023 at 4:46 am
YEEUN KO
Subscribermutual inductance : M=k(L1*L2)^(1/2)
So what you mean is that I can know L1, L2, and k (inductive coupling coefficient) through maxwell, so I calculate it using the formula above to get the mutual inductance, and this mutual inductance is equal to the magnetizing inductance?
And thank you so much for your reply!
December 8, 2023 at 5:08 am
YEEUN KO
SubscriberOh, by any chance, do you mean to think of 0.00031562 as the magnetization inductance in the photo above?
December 8, 2023 at 3:33 pm
GLUO
Ansys EmployeeYes-
December 10, 2023 at 12:13 pm
YEEUN KO
SubscriberBut why do you think magnetization inductance and mutual inductance are the same?
December 11, 2023 at 9:13 pm
GLUO
Ansys EmployeeThey are different by turns ratio. Please check Eq 2.8 on Leakage inductance - Wikipedia.Â
GL
- The topic ‘how can i calculate magnetizing inductance of transformer?’ is closed to new replies.
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
3862
1414
1220
1118
1015
