TAGGED: ansys-workbench, applying-load, static-structural
October 11, 2021 at 7:08 am
ali_i_96
SubscriberHello ,
I want to ask if there is a code that we can write in commands in static structural analysis in ansys workbench , to apply a force which depend on many variable ,
by example : F = M*K*(1-T) , and M , K and T are varying with time , so we have 3 variable that changes .
Thank you .
October 11, 2021 at 8:29 amRameez_ul_Haq
Subscribertime dependent analysis is not a static structural analysis. Transient analysis is an analysis type where the force depends and varies with time. Static Structural analysis means that for a specific amount of force, how my structure will deform when in equilibrium. If you want to conduct an analysis in Static structural, then you can define some substeps and observe the static results for each of substeps. But it depends on at how many substeps you want to observe the static results of the structure.
Viewing 1 reply thread- The topic ‘How can I apply a function force dependent on many variables in Static structural ?’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
- Nonlinear Adaptive Region not Splitting
Top Contributors-
3852
1414
1220
1117
1015
