How can fix Drucker-Prager cap plasticity integration algorithm did not converge problem?
    • edoniyasbirhanu
      simply supported beam stimulated using ANSYS APDL
      , MATERIAL MODEL used are the following
      concrete CPT215
      REINFORCEMENT REINF 264
      GFRP REINF 264
      after stimulation the warning file showed Drucker-Prager cap plasticity integration algorithm did not converge, how could fix this problem?
    • edoniyasbirhanu
  • The topic ‘How can fix Drucker-Prager cap plasticity integration algorithm did not converge problem?’ is closed to new replies.
