How can ANSYS simulate Flame Hardening of steel (gradient in yield strength)?
    • Ult0944
      Effectively flame hardening creates a gradient yield strength, on the surface of steel.
      Basically two flat ended cylinders pressing together under extreme loads.  Annealed material will yield at the contact surface, but after flame-hardening, there's no yielding under the same extreme loading.
      How would you simulate this gradient in yield strength?
Viewing 0 reply threads
  • The topic ‘How can ANSYS simulate Flame Hardening of steel (gradient in yield strength)?’ is closed to new replies.
