March 5, 2018 at 10:02 pm
Vassili BRIODEAU
SubscriberHello everyone,
I have been interpreting some User-defined functions, and now I would like to use User defined scalars. Quite a lot of people use them, yet the documentation is not that clear about the steps to follow. Basically, after interpreting, when I launch the calculation, Fluent crashes and closes. I don't have time to see what kind of error it is, but I think it is written: MPI error.
I will describe the steps I use, hoping it would help others.
Step 1: Writing the UDF in a .c file
/* Defining the adsoprtion of the system */ /********************************************/
#include "udf.h"
int ads;
DEFINE_ADJUST(adsorption,domain){
Thread*t; cell_t c; real E,A,P;
thread_loop_c(t,domain){
begin_c_loop (c,t){
real tem=C_T(c,t);
P=C_P(c,t)+RP_Get_Real("operating-pressure");
E=3080+18,9*tem;
A=8,31429*tem*log(1.47E9/P);
C_UDSI(c,t,ads)=71.6*exp(-A*A/(E*E));}
end_c_loop(c,t)}
      DEFINE_SOURCE(energy_source,c,t,dS,eqn){
         real e_source;
         e_source=-C_UDSI_M1(c,t,ads)*0.496056352e3*3080*sqrt(log(71.6/C_UDSI_M1(c,t,ads)));
         dS[eqn]=0.0;
         return e_source;
 Step 2: Interpreting the UDF
Step 3: Adding a User Defined Scalar (UDS)
In Flux function, I chose Adsorption, corresponding to the UDF using the UDS
Step 4: Hooking the UDF
I hooked adsorption as an adjust function
Step 5: In Cell Zone condition>cross Source>Source>Energy source> Choose UDF energy_source.
Step 6: Initializing. Everything ok (hybrid initialization)
Step 7: Running calculation. When it comes to the first iteration, Fluent crashes. Infortunately, I don't have time to take a screenshot.
Where does it come from? Did I forget a step or something in the programme?
March 6, 2018 at 4:40 pm
Vassili BRIODEAU
SubscriberHello,
Small update: I compiled the function instead of interpreting it. Then while compiling, I got the following error messages
udf_names.c(6) : error C2449: trouv? '{' au niveau de la port?e du fichier (en-t?te de fonction manquantÿ?)
udf_names.c(18) : fatal error C1004: fin de fichier inattendue rencontr?e
Translation to English:
found '{' at file scope (missing function header?)
unexpected end of file found
I looked on the internet, the first error means I could have a semicolon after an opening bracket, the second means the end semicolon is missing, however, I see neither one nor the other error in the programme.
April 19, 2018 at 7:30 pm
marinak
SubscriberBonjour!
1. Have you tried running any example from User Guide?
2. How do you compile/attach your UDF? This is how it works for me:
/define/user-defined/compiled-functions/
load
3. Why do you define ads variable outside DEFINE_ADJUST?
4. I would try to remove almost everything and leave simple code smth like result = 1; and try to compile it.
5. Also remove all the comments, sometimes compilator does not understand that /* initiates comment and gives errors. (In fact,i think it might be the case here)
- The topic ‘Hooking UDS to the model’ is closed to new replies.
