April 25, 2024 at 1:51 pm
Jeff McClintic
SubscriberIs there a way to set your own point to calculate hole location? When you grabe the origin of the x,y at the red anchor and move it, there are locations to choose from, but can you define your own location? Example. I would like to create my origin at the center of this large hole (C21 area). Can this be done?
April 26, 2024 at 6:01 am
Devendra Badgujar
Forum ModeratorHi Jeff,Â
I will check and get back to you on this.Â
Regards,Â
Devendra
April 26, 2024 at 3:11 pm
Jeff McClintic
Subscriberthank you
May 6, 2024 at 8:45 am
Atharv Joshi
Currently, its not possible to define Hole Table Origin at a user defined location. Â
When you select an hole table origin, all valid origin positions display as red origin points. These origin points remain visible until you begin to drag the origin to a different position. As you drag the origin, the X and/or Y coordinates data in the Hole Table immediately updates to provide a preview of X and Y coordinates data for the various origin positions.
I have created an enhancement request on your behalf for this feature.Â
Thanks and Regards
AtharvÂ
- The topic ‘Hole Table set your own location.’ is closed to new replies.
5794
