September 20, 2023 at 11:57 am
September 20, 2023 at 12:44 pm
Devendra Badgujar
Forum ModeratorHello Roberto,
Did you create these holes from within SpaceClaim Standard hole option? Then in the Standard hole you have option to measure depth to the tip and add create a hole from top to the tip of the drill point. Please check the image below for your reference. Â
If the hole is not created in SpaceClaim, then you might want to have a point at a tip and then you can measure it from the top since it would generally measure the hole depth without the drill points.Â
Let me know if this helps.Â
DevendraÂ
September 20, 2023 at 1:02 pm
Roberto
SubscriberHello Devendra
everything is very clear, it would be convenient if, as an improvement, the tip could be dimensioned without having to create the point.
Even if the hole was created with SpaceClaim, it is not possible to take the measurement if a user wants to quote it.
As it is not possible to attach a video here I will send it by email
Regards
September 27, 2023 at 1:43 pm
Konstantin Semyonov
SubscriberI would create a plane that goes through the axis of the hole and use it as a sketch plane. Then I would create a construction line and measure that. That is the best and the most accurate way in my opinion.
- The topic ‘Hole’ is closed to new replies.
5674
1890
1419
