April 29, 2024 at 7:24 am
nhanani4
Subscriberwhat is the default joint properties stiffness about local joint X?
May 1, 2024 at 2:50 pm
Forum ModeratorI don't think there are any default properties for stiffness in the CFD codes. Which solver are you using?Â
May 12, 2024 at 2:25 pm
nhanani4
SubscriberI use the ansys aqwa that has the hinged artificial.If it has the default stiffness for the artificial hinge joint?
- The topic ‘Hinged joint’ is closed to new replies.
1331
1147
