September 23, 2020 at 11:19 am
muath
SubscriberHello everybody nI have a problem when I use the high roughness (icing) model instead of standard one. I am simulating 2D flow on rough flat plate the roughness are given as an equivalent sand grain roughness profile. nthe problem that I am getting this massage nwall_transition_coeffs: Unknown bc typenInternal error at line 3000 in file 'turbulence\sg_ke.c' on Node 6nand the solution goes very slow. when i use the standard roughness model i have no problem or when I disable the intermittency equation.nwill be great if someone helped me with this issue.nthxn -
September 28, 2020 at 2:20 pm
Konstantin
Ansys EmployeeHello,nAccording to Sec. 7.4.15.2.8.2. Additional Roughness Models for Icing Simulations of Fluent 2020 User Guide, the high roughness model is compatible only with Spalart-Allmara and SST k-w. it is not compatible with transitions modelsn
- The topic ‘high Icing extension with intermittency model’ is closed to new replies.
- affinity not set
1487
1338
1188
