high continity residual for LES simulation for flow over aerofoil
    • zels496
      I am running Iincompressible LES simulation for NACA0012 aerofoil. My simulation domain is 3 c upstream, 7 downstream and 3 c to upper and lower boundaries and 0.1c in spanwise direction. The LES simulation is initialized using RANS steady state simulation.
      RANS steady state velocity field
      i used two boundaries as inlet (velocity inlet) and i define the velocity components ( ucos(10.8),usin(10.8),0) and other two as pressure outlet, while the front and back are periodic.
      The solver used for solving momentum equation is PISO solver ,fixed time step of 1e-6 is usedand max number of iteration/time step is 4
      The schemes used in the simulation second order upwind for momentum,second order for pressure and least square cell based for the gradient
      The relaxation factor is 0.3 for pressure and monetum
      The problem is that the continuity residual does not reach the set residual convergence 1e-6 after 4 iteration/time step
        iter        continuity      x-velocity        y-velocity      z-velocity      time/iter
        61163   1.9651e-05   3.8508e-07   3.3605e-07    3.6221e-07   0:001  20
        61164   2.4330e-05   7.6474e-07   6.7809e-07    7.3229e-07   0:001  19
        61165   2.0330e-05   5.4125e-07   4.7720e-07    5.1500e-07   0:00:27  18
        61166   1.9703e-05   3.8512e-07   3.3598e-07    3.6219e-07   0:00:28  17
        step flow-time lift flow-time drag
        9845 9.8450e-03 1.0801e+00 9.8450e-03 3.8341e-02
        Flow time = 0.009844999760389328s, time step = 9845
      is there something wrong in my case setting?
    • Amine Ben Hadj Ali
      Have you run precursor RANS simulation where you quantified the gird size and time step size required to resolve a certain amount of turbulence kinetic energy?
    • zels496
      Thanks for you reply Abenhadj
      after running the RANS simulation, I used the result as initial solution for LES using (init-turb-vel-fluctuations)
      I use this time step (10e-6) as it was quiet enough to keep convective courant less than 1 over the simulation domain
      The y+ value over the aerofoil is between (1-3) and the first cell height (1e-5).
      and x+ and z+ values are 200 and 150 respectively
      no of nodes on aerofoil is 312 and 21 nodes in the spanwise direction
      chord length=0.3048m
      free stream velocity=71.3 m/s and Rynold number is 1.5 million
      best regards
      Zein
      Still coarse for real LES. Please re-check the grid in precursor run or use SBES.
    • zels496
      I changed simulation to SBES but still have the same problem with continuity residuals
      As I said still coarse your run: you need to quantify in precursor run if you are having enough resolution.
      Moreover you can start from scratch now and not from steady-state result.
      Add more information about your model (even the LES one) + pciture of let say 100 time steps where one can easily check the behavior of the residuals.
    • zels496
      I have check y+ value and it is between 1-3, while x+=200 and Z+=150,so this means that the grid resolution is not enough for LES but i think it is reasonable for SBES
    • zels496
      This is the residuals for LES simulation
      The LES subgrid model is WALE.
      The mesh is around 1.7 million control volume
      SRS methods are not only for wall regions: if you are not paying the appropriate resolution in the bulk you are just doing an expensive URANS.
      Residuals looks okay: better to plot small number of them to see whether you have a monotonic decrease or not.
    • zels496
      This is the residual plot (no of iteration/time step=5) for 40 time steps
      is there guidlines for the mesh away from the walls?
      You might allow more iteration per time step: Say max 10 and set Report Interval to 3.
      LES or SRS Grid cannot just be judged by just looking into it. But what you are sharing is fine probably very fine in the regions of no interest. For that reason a precursor run. Seems that the wake region is not really well resolved if the wake does deflect to top or bottom.
    • zels496
      i will run the simulation for zero angle of attack on the same mesh and check if the continuity residuals are affected or not
      Have a fun!
Viewing 13 reply threads
  • The topic ‘high continity residual for LES simulation for flow over aerofoil’ is closed to new replies.
