Ansys Free Student Software
High wing lift coefficient value of a 3D wing
    • francescomarrocco1207
      Hi everyone, i am analizing a 3D wing that have a naca profile 63412, 0° AoA, velocity 300 km/h..Why when i calculate the lift coefficient (solution -> report definition->lift coefficient->compute) i get a value of 3300? i mean, shouldn't the lift coefficient have a value ranging from 0 to 1.5 more or less?  Also the drag coefficient has a high value (205), while the lift force is acceptable (2400 N). Could someone help to understand why of these high value? Thanks
      It's a coefficient. Look at the definition carefully, if you didn't alter the reference values you'll get an unexpected result. Alternatively, check you're using air, water can produce a similar effect! If you check the examples in Fluent's Help there are a couple of NACA wings modelled which will show you how to work with the coefficients.
        Hi Rob thank you for your answer..i'm using air at sea level, could you link these NACA examples please? i don't find them
      https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/prod_page.html?pn=Fluent&pid=Fluent&lang=en   and Learning (left tool bar on here).
