3D Design
3D Design
Hiding bends and shifting values in unfolding
    • Lukas Janicek
      Can you tell me if it is possible to hide the bends in the development in the drawing - I will only see the contour?
      I'm also wondering how I can move the bend values to a different location.
      https://www.dropbox.com/scl/fi/vg7z28n0fc9u2ivu6k5tj/SC-Hide-bends-move-value.mp4?rlkey=n0vjywl4sig8fm58i8vqo24cc&st=6fgjj8mp&dl=0
      Thank you.
      Lukas
    • Subashni Ravichandran
      Hello
      I see that the bend lines seem to be off in the model you have shown in the video. Do you mean you would like to hide the edge of the bend as well?
      In that case, as it is a part of the geometry the edge cannot be hidden.
      But if you intend to hide the bend lines, you can manage their visibility through the Layers panel. Bend lines and bend dimensions are placed on a Bends layer which is turned off by default. To change the visibility, you can turn the visibility on or off in the Layers panel.
      Regarding moving the bend dimension, the dimesion can be moved in the unfolded geometry(see image 1). Once it is moved in the geometry it will reflect in the Drawing sheet as well.(image 2)
      (Image 1)
      (image 2)
    • Lukas Janicek
      Hi Subashni,
      I finally found out that this is possible with the Highlight button.
      Have a nice day.
      Lukas
  • The topic ‘Hiding bends and shifting values in unfolding’ is closed to new replies.
