November 17, 2021 at 7:16 am
Dimitri Goethals
Subscriber? This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & ConditionsHi, Why is the hidden line representation of the step file in attachment not OK, Is there a specific setting causing the "long" edged to disappear? Shaded View
Hidden Line
 As you can see only snippets of the part are correctly displayed.
Thanks in advance for any help.
Regards
Dimitri
November 17, 2021 at 7:28 am
Charudatta Bandgar
SubscriberHello Dimitri G
Let me check this, I will get back to you.
Regards.
November 17, 2021 at 8:24 am
Charudatta Bandgar
This is a known issue that we have come across and a bug ticket has been filed (535178), especially when the file is imported from some other format (step, etc.). I do not think that this happening due to the larger length of the edge. I tried splitting the geometry to a shorter length, with no help. The developers think that this could be either a translation issue or the geometry itself might have some issues. This is expected to be fixed in future release.Â
Regards.
November 17, 2021 at 8:34 am
Dimitri Goethals
SubscriberHi Charudatta Bandgar ,
Thank you for you swift reply.
I have seen that if you pull the flanges so the become longer, the result starts to improve.
So maybe the size does matter a bit.
I will pass this info on to my customer.
Regards
November 17, 2021 at 8:48 am
Charudatta Bandgar
So maybe the size does matter a bit. Thanks for this information, but I am not noticing this as well on my end. But I will forward your observations to the developers.
Regards.
- The topic ‘Hidden Line Display setting not showing everything’ is closed to new replies.
5799
