January 4, 2024 at 9:23 pm
Noura Mansour
Subscriberi want to get nonlinear graph between force and displacement I tried but the spring at small forces get graph linear between force and displacement and when i increase the force the spring make deflection in axis prependicular to axis of compression that cause error
January 4, 2024 at 11:50 pm
peteroznewman
SubscriberIt would help us understand your model if you include some images in your reply. An example of a nonlinear spring is a conical spring (like the spring under the negative terminal of a battery compartment) where the coils build up on the base platform as the spring is compressed. You need to define contact between the spring and the base and turn on Large Deflection to see the nonlinear spring force.
January 7, 2024 at 11:47 am
January 7, 2024 at 11:55 am
Noura Mansour
Subscribercan i know type of contact .. and i insert contact between spring and bas or contact between coils of spring alsoÂ
January 7, 2024 at 4:04 pm
peteroznewman
SubscriberUse Frictional Contact. You will need to define self-contact between the spring and itself as well as the spring and the base.
January 7, 2024 at 11:01 pm
Noura Mansour
SubscriberWhat are you meaning by spring and itself
January 7, 2024 at 11:50 pm
peteroznewman
SubscriberIn the Contact defininition, you must select one or more faces for the Contact side and one or more faces for the Target side of the contact.
Select the same face(s) for both. That is self-contact.
January 24, 2024 at 11:54 am
January 24, 2024 at 9:32 pm
peteroznewman
SubscriberLooks like your mesh is not connected. In SpaceClaim, on the Workbench tab, use the Share button.
January 27, 2024 at 2:24 pm
Noura Mansour
Subscribersorry how can i do it ?
i use anys workbench 2023 R1 -
February 8, 2024 at 11:46 pm
February 9, 2024 at 2:11 am
peteroznewman
SubscriberHere is a long list of Google Search results for the term "unable to converge"
Please read most of these discussions for guidance on how to fix this problem.
February 10, 2024 at 7:02 pm
January 27, 2024 at 2:59 pm
peteroznewman
SubscriberIn Workbench, right click on the Geometry cell and Edit in SpaceClaim. In SpaceClaim, on the Repair tab click the Extra Edges button then the green check. Click the Extra Points button also. On the Workbench tab click the Share button then the green check. Close SC. Open the Model. You may need to reselect some faces to repair lost scoping.
- The topic ‘hi i want to simulate a nonlinear spring (barrel and hourglass)’ is closed to new replies.
6710
1313
