October 20, 2023 at 3:40 am
지완 서
SubscriberIn steady simulation, finally i click run calculation and can see pseudo time settings.
In this setting, i use default value. After that, i change Time Scale Factor 1 to 0.1 or 0.01, then my solution(Drag coefficient) is change depend on time scale factorwhat is Time Scale Factor?
How i can get proper time scale factor value?
we can calculater CFL. Can we calcuater time scale factor?
My english is bad. Thanks read my question.
October 20, 2023 at 2:33 pm
Forum ModeratorIt's an equivalent to CFL, if you search in Fluent's Help you should find an explanation.Â
October 20, 2023 at 2:42 pm
지완 서
SubscriberThanks for your answer.
Your answer means time scale factor effect same as CFL.Â
Then, calculating time scale factor is same as CFL?
October 20, 2023 at 2:44 pm
Forum ModeratorEquivalent, not the same. You should check the value in Fluent is appropriate for your model, the default may be a too high for some cases.Â
October 20, 2023 at 2:47 pm
지완 서
SubscriberSorry, my english is bad
Thanks :)I will read fluent's explanation and check my model
- The topic ‘Hi, guys. I want to know what is ‘Time Scale Factor’ in ansys fluent’ is closed to new replies.
5824
