Electronics
Electronics
HFSS: Using Q3D to solve the DC point
    • m.harasim
      When using the "Use Q3D to solve the DC point" option, within a frequency sweep in the HFSS, the simulation returns the following error:
      The simulation profile contains the following information:
      The model consists of a PCB cutout and additional bodies: part of a housing, connector enclosure, a few wires (geometries united with the connector pins) and a copper bar connecting the housing to a reference plane:
      The aforementioned reference plane is a "Perfect E" boundary assigned to the bottom face of the airbox:
      There are multiple lumped ports and RLC boundary conditions defined between various copper lines/planes of the PCB:
      My goal is to compute a scattering matrix of the PCB, to be then used in a transient analysis (utilizing the Nexxim solver in the Circuit environment). Hence I need to sweep the frequency from the DC up to the end of the bandwidth of interest (400 MHz):
      The HFSS mesh is computed for the 400 MHz:
      I haven't found any details regarding the error message. Could you please explain the meaning behind it?
      Best regards,
      Maciej
    • alexandre-antoi.bourrieau
      I got same problem... hopping someone will help us !
    • shahidaziz_khan
      any solution to this problem?
