March 6, 2024 at 5:05 am
Mete Balci
SubscriberHFSS transient solution setup does not include some parameters, I wonder if they are not used by the transient solver or they are implicitly defined or derived from other parameters. Namely, transient setup only has:
- maximum number of passes and maximum delta S
- input signal as broadband pulse with min/max freq or TDR pulse
As opposed to an HFSS solution, there are no options for:
- solution frequency (Adaptive Solutions > Frequency): is this derived from the input signal in transient solutions setup ?
- initial mesh options, lambda refinement: is the default lambda target 0.3333 always used ?
- maximum refinement per pass: is it always 30% ?
March 12, 2024 at 2:20 pm
Aymen Mzoughi
Ansys EmployeeYes indeed these are two different solvers relying on different techniques
- The topic ‘HFSS transient solution setup’ is closed to new replies.
Ansys Innovation Space
1057
1051
965
942
