HFSS to Ansys Fluent EM mapping/data coupling
    • Arunachalam Kavitha
      We are working on a problem that requires analysis of temperature/heat generation due to EM radiation from a horn antenna. The problem consists of a horn antenna with a given excitation of 10000W. Horn antenna material is copper and it is placed inside an air domain.
       For the temperature analysis we have tried linking the HFSS with Ansys Fluent but we are unable couple the data or do the EM mapping from HFSS to Fluent.
      We have tried getting help from local Ansys support since last two months, but the solution for the problem is not yet obtained.
      Help from anyone in any form will be much appreciated.
      We will share the workbench file if needed.
      Other than the tutorials (I think there's one) I can't comment. Do you need to transfer EM or just heat?
  • The topic ‘HFSS to Ansys Fluent EM mapping/data coupling’ is closed to new replies.
