Electronics
Electronics
HFSS simulation clarification
    • underground45
      I was simulating a patch antenna for resonant frequency of 2.5GHz and my S11 has a peak at 2.55Ghz, how do I get it to 2.50Ghz?
      I am uploading my project. I figured adjusting the length of the patch will do the trick but I have tried and I lose more -dBs when I do that. Any help? Thanks
    • VivekKamble
      The antenna resonance frequency depends on many parameters such as the length & width of the patch, the height of the substrate, etc.
      You can optimize the design by using Optimetrics in the project manager window.
      Right-click on Optometrics >> Add parametric then add parameters and Analyze.
      Please refer HFSS help document for more information.
  • The topic ‘HFSS simulation clarification’ is closed to new replies.
