December 4, 2023 at 5:53 pm
imtiaz
SubscriberWhen I used an SMA connector instead of a hfss port (lumped/wave), it returned an incorrect s11 (see attached image). Everything is fine because the pin is properly connected to the antenna's feed line.ÂÂÂ
But why it is showing this type of behavior?
Are there any additional things need to do when I try with a SMA Connector model?
December 6, 2023 at 5:29 am
Praneeth
Ansys EmployeeHi Imtiaz,
It looks like there is an issue with the model. It looks like the signal is completely reflected back to the port. Please check the following in your model with the connector:Â
- Did you make sure that the connector outer conductor is only touching the ground planes?
- Did you make sure that the connector inner conductor is only touching the signal trace?
- Did you verify the port excitation on the SMA connector?
- Is there an explicit air region or how did you model the surrounding region?
- Are the dimensions for the SMA connector correct?
Best regards,
Praneeth.
- The topic ‘HFSS Port vs SMA Connector in Design – Provide wrong S11, Why?’ is closed to new replies.
Ansys Innovation Space
1388
1188
1090
1015
