Electronics
Electronics
HFSS parameter Study – run only selected sets
    • nherscovici
      Sometimes, when I run a parameter study the model collapses and the permeter study  crashes.
      Q1. is there a way to bypass the cases where the model crashes?
      Q2. is there a way to run only some of the variable sets but not all the combinations?
      Thank you
    • Takeshi Itadani
      Is it a specific combination of parameters that causes the crash? If so, when you set the values of those parameters to variables, do they display the model geometry, etc. without any problems? Also, does the Validation Check detect any problems?
      Why not use the Table tab in Parametric setup to remove unnecessary parameter combinations for analysis?
    • nherscovici
      I was not aware of the option to delete the failing combinatins
      Thank you
    • nherscovici
      Is there a way to bypass crashhing combinations in optimization too?
    • Gia
      You can use the menu option [View > Animate] to test your model parameterization and find the limits where the model generates invalid geometry.
      In the optimization tab of the design properties window (where the variables are defined), you can limit the min/max allowable value for optimization runs.
    • nherscovici
      I am aware of that, but this does not help much. It's the combination of certain parameters values that can create the crush. The user can't predict that combination because it is generate by the optimization algoritm.
      I think the ony way is to have an option which tells the optimizer algorithm to exclude the case from calculation if the validation of that specific combination creates an unsovable project design.
Viewing 5 reply threads
