August 28, 2025 at 1:42 pm
jimmy.nguyen
SubscriberHi all,
I am submitting a script using sbatch to a SLURM cluster. I am using HFSS 25R1 without a graphical environment.
I see the output:
[warning] For machine [...] libnvidia-ml.so is too old or could not be found in : 1) /usr/lib64 or 2) /usr/lib/x86_64-linux-gnu or the system default paths. The libnvidia-ml.so binary is required for GPU acceleration and therefore only CPU will be used. For further information contact Ansys support.
I am using CUDA 12.3 and have a driver version of 545.23.08. The CUDA libraries are not installed in either /usr/lib64 or /usr/lib/x86_64-linux-gnu. They are in a different directory. I added this directory to LD_LIBRARY_PATH, yet ansysedt does not appear to be able to find it.
August 29, 2025 at 7:18 am
Ivonne Marti
Ansys EmployeeHi jimmy.nguyen,
To resolve this warning, you can try the following options
§ Check for the Library: Ensure that the
libnvidia-ml.solibrary exists in its default directory, which is typically/usr/lib64. If it is not present, you may need to install or update your NVIDIA drivers.§ Update NVIDIA Drivers: Visit the NVIDIA website to download and install the latest drivers for your GPU. It's important to install drivers directly from the NVIDIA website rather than using the Windows device manager update. After installation, make sure to restart your computer to apply the changes.Â
§ Create Necessary Directories: If the directory
/usr/lib64is missing, you may need to create it and ensure that thelibnvidia-ml.sofile is placed there. You can also add its path to the Linux environment variablePATHthrough a shell startup file.ÂMore detailed information can be found in the HFSS Help page 1988
§ Enable/Disable GPU Acceleration: You can manage GPU acceleration settings from the Ansys Electronics Desktop Solver User Interface. This might help in resolving any configuration issues related to GPU usage.
I hope it helps
August 29, 2025 at 1:18 pm
jimmy.nguyen
SubscriberI have added my CUDA install directory to LD_LIBRARY_PATH and PATH, yet there appears to be no change in behavior.
1) Which NVIDIA driver version is required by 2025R1?
2) Are there any debug options/flags that I could use to run ansysedt and see if it immediately detects a GPU? Currently I am submitting jobs to the SLURM cluster and reading back the log files, which takes a while.
shown below is my slurm script if it helps:#!/bin/bash
#SBATCH --export ALL
#SBATCH --chdir '/projects/users/jimmy'
#SBATCH --job-name project1
#SBATCH --partition system.q
#SBATCH --nodes 1
#SBATCH --cpus-per-task 128
#SBATCH --ntasks 1
#SBATCH --gres gpu:1
#SBATCH --output /projects/users/jimmy/slurm-%x-%j.outmodule load slurm
module load cuda12.2/toolkitexport ANSYSEM_GENERIC_MPI_WRAPPER=/software/hfss/2025R1/v251/AnsysEM/schedulers/scripts/utils/slurm_srun_wrapper.sh
export ANSYSEM_COMMON_PREFIX=/software/hfss/2025R1/v251/AnsysEM/common
export ANSOFT_PASS_DEBUG_ENV_TO_REMOTE_ENGINES=1
export LD_LIBRARY_PATH=/cuda/libs/current/lib64:$LD_LIBRARY_PATH
export PATH=/cuda/libs/current/lib64:$PATHsrun /software/hfss/2025R1/v251/AnsysEM/schedulers/scripts/utils/ansysedt_launcher.sh
srun --overcommit --cpu-bind=none --mem-per-cpu=0 --gpus-per-node=1 --overlap /software/hfss/2025R1/v251/AnsysEM/ansysedt -distributed includetypes=default maxlevels=1 -machinelist num=1 numgpus=1 -monitor -ng -batchoptions ' '\''HFSS/EnableGPU'\''='\''1'\'' '\''HFSS/NumCoresPerDistributedTask'\''='\''128'\'' '\''HFSS/RAMLimitPercent'\''='\''90'\''' -batchsolve HFSSDesign1 /projects/users/jimmy/Project.aedt
