3D Design
3D Design
HFSS generated Touchtone file format:
    • ASISH BHATTACHARJEE
      I have a touchtone file from HFSS with following format:
      # GHZ S MA R 50
      I want below format:
      # HZ S MA R 50
      I have HFSS design  available. The touchtone file generated is very big from HFSS. I can manually scale the frequency but that might not still 1-to-1 compatible between 2 formats. How can we get this format from HFSS results- solution data? Is there any intermediate tool like ADS can convert? This 2 formats are  significantly different for TDR plots  in another tool.
    • Gia
      The Touchstone file format standard allows for different units (Hz, kHz, MHz, GHz) to be used in the file given the appropriate matching header. - The file output by HFSS with unites specified in [GHz] should be able to be read / utilized in any third-party tools which properly implement the Touchstone file standard.
      If needing to convert the frequency units from [GHz] to [Hz], then I would reccomend writing a simple Matlab or python script to do this. - Touchstone files are ASCII text files which are straightforward to open, edit, and re-save. - An LLM tool like ChatGPT can generate a script to accomplish this task, however this is outside the scope of Ansys support.
