September 17, 2024 at 6:10 pm
tolber3
SubscriberThe coplanar waveguide with ground example file produces different results for me than the one found in the PDF ("coplanar_wg_w_ground.pdf") that comes with the file. I have only opened the file and clicked analyze on the "DC_10GHz" sweep to get the results. I am using a remote desktop to run the software.Â
PDF:
September 18, 2024 at 2:56 pm
Aymen Mzoughi
Ansys EmployeeThank you for pointing to this. It will be corrected in the upcoming release.
September 19, 2024 at 3:06 pm
tolber3
SubscriberIs there anything I can do to get the expected results? Is there an issue with my setup or does the newest version produce different results?
September 19, 2024 at 3:55 pm
tolber3
SubscriberI am using version 2023 R2. Which version does not have this issue?
September 24, 2024 at 3:20 pm
tolber3
SubscriberIs there any update on what is causing this issue or how to fix it?
1306
