May 4, 2019 at 2:11 pm
Juner
SubscriberHello,
how to create a dielectric resonator and analyze using the HFSS eigenmode solver, for to be able to solver the natural resonant frequencies and mode patterns of the cylindrical dielectric resonator alone.
Best regards,
Juner
May 8, 2019 at 12:20 am
3Asif
SubscriberHi Juner,
A good start can be trying from the built-in example.
In the installation folderÂ
File>Open Example
New pop-up window:
HFSS>RF Microwave>coaxial_resonator.aedt
You just change the solver and play with materials.Â
May 8, 2019 at 12:32 am
3Asif
SubscriberHi Juner,
You can follow the built-in Example.
File>Open Example.
It will be inside HFSS> RF Micorwave> and you will the resonator -
May 11, 2019 at 7:24 pm
Juner
SubscriberHi,
Thanks for the trouble!
- The topic ‘HFSS Eigenmode Solver’ is closed to new replies.
Ansys Innovation Space
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
1414
1220
1118
1015
