July 8, 2024 at 1:00 pm
2471853318
Subscriberhello. I have designed a 3D model in HFSSDesign model.I want to do the co simulation of this 3D model along with circuit elements.I use the plane wave excitation, but the plane wave excitation has no port representation in the circuit, how can I conduct field path co-simulation to see the final RCS?
July 31, 2024 at 11:16 am
dushyant.marathe
Ansys EmployeeHi Jie Tan,
Thanks for posting query on learning forum.
I assume that you have only plane wave source in HFSS 3D model. If you have only plane wave source and no port in HFSS model, then in circuit you will not get the terminal for port creation.
For HFSS circuit co-simulation you should have ports created in HFSS 3D model.
Thanks,
- The topic ‘HFSS design and circuit co simulation(plane wave;RCS)’ is closed to new replies.
