Electronics
Electronics
HFSS create setup based on the values from plots
    • ancan9360
      Hi, is there anyway to create a setup from the for example Modal Solution Data ? I simulated my branchline coupler (used full licence) with the interpolating setup where the center is 3.75GHz after the simulation I saw that S11 get its minimum value at 3.9GHz (used x marker). Now I want to create a new setup where its center is 3.9GHz but I don't want to put the value manually. I clicked on the marker to see some "create setup from marker" etc. but I did not see. Can you help ?
Viewing 0 reply threads
