September 17, 2025 at 10:10 am
23m1196
SubscriberI’m working on a PCB in HFSS 3D Layout where I’ve imported a connector as a .a3dcomp file. When I run the analysis, the analysis fails and the log shows an HFSS 3D layout intersection. Since the .a3dcomp is locked, I can’t select or edit its individual parts to resolve the overlap.Â
What’s the recommended way to handle geometry intersections between a 3D component and the PCB in HFSS?Â
Thanks.
September 17, 2025 at 11:31 pm
Takeshi Itadani
Ansys EmployeeThe 3D Component appears to be interfering with the Top layer in HFSS 3D Layout. Review the placement of the 3D Component, or consider editing the shape of the Top layer so that it does not interfere with the 3D Component.
Ansys Innovation Space
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
1414
1256
1118
1015
