TAGGED: -Structured-Meshing, cfd-icfluent, hexa-mesh, mesh, poly-hexcore
June 27, 2023 at 11:48 amAbhishek ShingalaSubscriber
Hello all,
Does anyone know what is the benefit of using "Hexcore" mesh in watertight geometry workflow, if the hexahedral cells are not aligned with the flow direction?
June 27, 2023 at 3:33 pmRobForum Moderator
Lower cell count, but you also risk jumps in cell size in inappropriate places. I tend to favour inflated poly mesh for most things, and really need to review the new multizone functions in Fluent Meshing.Â
- The topic ‘Hexcore mesh of Watertight geometry workflow in Fluent’ is closed to new replies.
Ansys Innovation Space
- Non-Intersected faces found for matching interface periodic-walls
- Script error Code: 800a000d
- Fluent fails with Intel MPI protocol on 2 nodes
- Cyclone (Stairmand) simulation using RSM
- error udf
- Diesel with Ammonia/Hydrogen blend combustion
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
594
591
535
366
