LS Dyna
LS Dyna
Hex Meshing Error: No mappable volume found!
    • Fernando Torres
      Greetings!
      How to 'solid mesh' this geometry through LS-PREPOST? Thanks :)
    • Ram Gopisetti
      Hi, did you have splits in your model, you need to split to have an mappable faces, or you may want to opt for ANSA or third party tools to have an proper meshing onto to solids.
      Cheers, Ram
    • Reno Genest
      Have a look at the LS-PrePost training:
      https://ftp.lstc.com/anonymous/outgoing/lsprepost/Training/Intro/
      You can mesh this geometry using tet elements. Or, if you need hex elements, you will have to slice the geometry into sweepable bodies. There is more information in the training above.
      Or, if you have access to Ansys Workbench, you can try using the Multizone meshing method in Mechanical to have hex mesh on this geometry. Or, you can use SpaceClaim to slice the geometry into sweepable bodies.
      Reno.
  • The topic ‘Hex Meshing Error: No mappable volume found!’ is closed to new replies.
