September 16, 2024 at 3:50 am
sudeepns.197me025
SubscriberHello All,Â
Greetings!Â
I am trying to simulate the Steam methane reforming reaction in Ansys chemkin.Â
I have developedÂ
1. gas phase reaction files
2. surface reaction files
3. Thermodynamic data files
4. transport data file.Â
This is a heterogeneous reaction.Â
The above files successfully get imported to chemkin, but while running the simulation, I am getting the following error.Â
" DASPK-- AT T (=R1) AND STEPSIZE H (=R2) THE                  Â   In above, R1 = 0.3196622577504D-10  R2 = 0.7023828905648D-15 DASPK-- ITERATION MATRIX IS SINGULAR.                     Â     SITE FRACTIONS AT REACTOR INLET CANNOT BE FOUND     THE MATRIX OF PARTIAL DERIVATIVES MAYBE SINGULAR     SEARCH FOR INLET SITE COVERAGE TERMINATED DUE TO ERROR(S)     Attempting to proceed without solution of initial surface site fractions"
Kindly help me in resolving the issue.ÂÂ
September 17, 2024 at 12:38 pm
Ren
Ansys EmployeeThe error messages suggest that the reactor has not been set up fully (missing site fraction data). Please also check the following files for any warning or error messages:
chem.out, surf.out, tran.out
.out in the run directory. Which reactor do you use?
What is the Chemin release number?
September 19, 2024 at 11:20 am
sudeepns.197me025
SubscriberHello Sir,Â
Thank you for the reply.ÂI am using PFR for steam methane reforming purposes.Â
Site fraction data I am giving in the input section of the PFR (Attached image for the reference).Â
I use 2024R2 Chemkin
Attached chemkin files for your reference.Â
Also, Requesting you to provide the working surface reaction file.Â
looking forward for your reply.
September 19, 2024 at 2:36 pm
sudeepns.197me025
Greetings,Â
I could able to get rid of site fraction error, however, DASPK Solver errror remains unrectified from my end.Â
I have attached a snap of the same for your reference.Â
The below are my solver inputs.Â
1. Absolute tolerance = 1e-302. Relative tolerance = 1e-22
3. Sensitivity absolute tolerance = 1e-18
4. Sensitivity relative tolerance = 1e-06
5. Solver maximum step distance = 0.01 nm
6. Scaling factor for relaxing surface equations = 1e-08 micro-meter/sec
7. Initial Time step = 0.01 nm
8. Initial integration step = 0.01 nm
9. Maximum relative change in site fractions = 1 e-06
10. Maximum absolute change in site fractions = 0.001
Kindly let me know, what changes are to be made to solve this error.Â
Looking forward for your reply.ÂÂ
5824
