November 25, 2024 at 11:24 pm
sjohn
SubscriberI have a case with Multiphase (VOF) and Species physics enabled. In the Specie Model, Species Transport and Voumetric Reactions are enabled. Phase properties are provided using chemkin-import. Finite-Rate/No TCI is checked under Turbulence-Chemistry Interaction. A thremodynamics databse file has been uploaded.
In the Multiphase Model window, under Phase Interaction, there is a form to provide information on heterogeneous reaction. Under the Reaction Rate Function option, I only see two options - none or user defined. I don't see option for arrhenius-rate. How can I get that option?
November 26, 2024 at 1:55 pm
Forum ModeratorOdd, I've got none and Arrhenius as options. That's with granular on or off for the second phase.Â
November 26, 2024 at 2:49 pm
sjohn
SubscriberGranular is off.Â
I am modeling a reaction where in two species react exothermically  in liquid phase to form gaseous species.Â
November 26, 2024 at 3:02 pm
Forum ModeratorIf they react in the liquid phase to form a gas why are the reactants from different phases?Â
November 26, 2024 at 3:35 pm
sjohn
SubscriberThey are not. Figure 26 is from the manual.
November 26, 2024 at 3:49 pm
Forum ModeratorCan you post a screen grab of what you're seeing?
November 26, 2024 at 5:53 pm
November 27, 2024 at 10:01 am
Forum ModeratorOK, I had the option, didn't and now do. I wonder if the number of species involved or "something" has messed with the GUI panel. Can you check the TUI commandÂ
/define/phases/set-domain-properties/interaction-domain/heat-mass-reactions react , yes
And just accept everything but the Arrhenius setting.Â
