Electronics
Electronics
HelpMe PLZ :( :(
    • HyoJoo LIM
      Hello, I am a Korean who is doing research for a Korean company
      I can't get a result.
      It does not continue at a 94% progress rate.
      The mesh quality is not bad.
      What's the problem?
      d7969d50-424d-45dd-90b7-1d1ff104a666.png (1656Ă—1039)15838d69-2f31-40f3-a293-6cef3c4e48dd.png (1652Ă—1034)
    • Timos
      Hello, could you please give a description of your simulation? Could you also insert the picture so that it can be seen in your post?
    • HyoJoo LIM
      Air flows in from the round (red arrow=inlet) and out from the square (blue arrow=outlet).
      This is the inner section.
      Green is the part where there is air flow.
      Following the arrow, air is introduced and discharged.
    • HyoJoo LIM
      If possible, I will give you the Discovery AIM file that I have, so can you check it?
      My email is lim1623712@keti.re.kr
    • Charudatta Bandgar
      Hello Hyojoo,
      Have you done it in Discovery AIM? What is the issue you are facing exactly.
      I am not sure if I understand it correctly, when you said 'It does not continue at a 94% progress rate.'. Is your simulation stuck at 94%?
      Regards.
    • HyoJoo LIM
      I am using Discovery AIM.
      Mesh and Flow have been set up without any special problems.
      But the simulation stuck at 94%.
      I don't know why the simulation stuck at 94%. :(
      What issues should I consider?
      Thank you very much for your help.
    • HyoJoo LIM
      This is my current Discovery AIM screen.
Viewing 6 reply threads
  • The topic ‘HelpMe PLZ :( :(’ is closed to new replies.
